GE 29897GE1 Corded Phone Logo
A
Anonymous Posted on Jun 25, 2014
How do I set up My greeting - GE 29897GE1 Corded Phone
Model TC 25250 RE - how to retrieve outgoing greeting? Phone was disconnected and than I plugged in and greeting/outgoing is lost?? I was told I can retrieve it?? Can you help??
Change your greeting To use a different greeting that you already recorded or switch back to the default greeting:
  1. Open the Google Voice app .
  2. At the top left, tap Menu Settings.
  3. In the Voicemail section, tap Voicemail greeting.
  4. Next to the greeting you want to use, tap More Set as active
How do i set up greeting on phone?
Go to Google Voice. Click the gear icon at the top right of the Google Voice window and select Settings. Click the Voicemail & Text tab. In the 'Voicemail Greeting' section, click Record New Greeting. Enter the name for the greeting you're going to record and click Continue.
How to record a new greeting
  1. Go to Google Voice.
  2. Click the gear icon at the top right of the Google Voice window and select Settings.
  3. Click the Voicemail & Text tab.
  4. In the 'Voicemail Greeting' section, click Record New Greeting.
  5. Enter the name for the greeting you're going to record and click Continue.
  6. A "Record Greeting" box will appear. Select one of your forwarding phones from the "Phone to ring" drop-down menu.
  7. Click Connect.
  8. Google Voice will call you on the forwarding phone you selected. Pick up the call and record your voicemail greeting when prompted.
  9. Once you've recorded your voicemail greeting, make sure it's selected in the 'Voicemail Greeting' section of your Settings.
  10. Click Save changes at the bottom of the page.
2answers
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 • Cell Phones
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
2answers
I am trying to set a new greeting for our voicemail system for when our office is closed next week. I recorded what i want as greeting # 2, and when i go through the automated menu, i listened and the...
It sounds like what your calling greeting 2 is actually the night message (1 for day menu 2 for night menu)did you try calling with the night key on?
3helpful
2answers
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Our Automated Attendant for our Norstar M7310 is picking up the wrong message. Where do we change that?
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
