Precor EFX 546i Elliptical Version 4 Logo
A
Anonymous Posted on Jun 25, 2014
Precor efx546i error 30 - Precor EFX 546i Elliptical Version 4
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Jul 28, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514501
Points
111994
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
How do you fix an error code 30 on a precor 954i?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
2answers
What is error 30 on the precor 9.33i treadmill?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Error 30 on precor 546 efx
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Precore efx 546 error 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
CHARGE BATTERY ON PRECORE EFX546I
The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Error 30 for elleptical precor efx5.23
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
How to fix Precor EFX 5.17 error code 30
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
What does error code 30 mean on the Precor efx 576i?
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
