Whirlpool ADP 4108/1 start button keeps on flashing. I just need to know how to reset please
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
SOURCE: start light keeps flashing but washer won't operat...
Check whether inlet water is flowing into the machine.
SOURCE: clean button will just flash need to know how to reset
The clean light is flashing due to a failure in heating the water properly. Follow the link below for instructions on resetting the control and information on what may have caused the failure. Let me know if it was helpful.
Clean light flashing
SOURCE: the wash light and the start/cancel button keep
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
