Question about Hotpoint Aquarius WF000 Front Load Washer
Water inlet valve problem
Water seems to struggle to get into the machine . if I remove the soap tray I can see the water trickling into the machine. feed pipes are clear. pressure is good.
SOURCE:
catriver
  • 878 Answers
SOURCE: Water Leak
Raf, remove the soap dispensor and check to see if you have a bottle cap gasket blocking the fill port. Just use your finger and probe around where the port is. Catriver..post back.
Posted on Oct 16, 2006
dazmaraz
  • 67 Answers
SOURCE: Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
Posted on Aug 07, 2007
  • 1294 Answers
SOURCE: Water Leak
If possible pull out your drawer and clean it up. Reason due to clogging with detergent, etc. Refer to your manual. If you can't get the drawer out, use a tooth brush to scrub; see that brush does not fall in. The dirt can fall in. To test if clear, pour water into drawer by opening it just so the water will fall in. Try all the drawers.
And rate me pl......
Posted on Dec 02, 2007
  • 183 Answers
SOURCE: water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Posted on Dec 25, 2007
barkencoa
  • 3463 Answers
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Posted on Dec 28, 2008
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
I have an old whirlpool stylemaster no.907675 and the water is just trickling out! Is this a filter problem? I have no idea how to fix this!!! Help please!
Water trickling is a sign of clogged inlet screens or faulty inlet valves. First turn off the water, remove the two hoses inspect them for debris. If clogged use a tiny hook to remove the screens clean and install. If they are not dirty your inlet valves are bad. Also has your water pressure seem any less in pressure? Good luck!
Mar 19, 2013 | Washing Machines
A steady stream/trickle of water leaks from tube behind the soap tray and flows out of the spout onto the inner rubber door gasket.. When I plug the tube with my finger, it give a "poof" of...
looks that you have problems with your water valve. make sure the fill hoses screens are clean and valve screen too. check water pressure, you need 20psi or more. if all checks good then replace water valve.
Feb 09, 2011 | Kenmore Washing Machines
I haven't used the miele novotronic washing machine in our other house for a year and noticed when i tried today the water was only dribbling into soap tray-thereis enough pressure in water feed so feel...
hi,
More than likely the problem is actually the inlet valve which only partly allows water to flow into the unit. you would need to remove the lid and replace the inlet valve which is on the left hand back corner of the unit. Valves are available from Miele
Jun 07, 2010 | Miele Novotronic Premier 500 Front Load...
My HE3 is filling up with water when not being
You need to replace the water inlet valve. It isn't closing completely when the machine turns off.
However, if the hoses to the back of the washer have their own cutoff, turning them off when you are done will fix it too... you just have to be there when the machine stops.
Jan 08, 2010 | Washing Machines
After wash is done there is still soap on the laundry help!
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Kenmore Washing Machines
We have a Kenmore oasis washer model 110 27062601 that does not rinse the clothes properly. You can rinse then twice and the clothes still come out with soap scum on then, the black clothes are really...
3. On the washer side - look for a removeable screen inside where you just removed the hose.
8. re-try.
Feb 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
There's a foamy soap left in my washing machine after the laundry is done. We've established that I'm NOT putting in too much soap; it just isn't rinsing properly. The repair guy says it is draining fine,...
8. re-try.
Feb 21, 2009 | Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
