Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
How to replace the battery in a Howard EH23GA wrist watch?
2 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: How do you change battery
The back does not come off (case is in one piece); it's the bezel -- the metal rim that holds the front glass crystal.
There is a small notch in the rim of the bezel (on mine, this aligned with the 'lower left' lug on the case around 7:00 on the face). Be careful as there is an O-ring to waterproof the watch, and this notch goes right into the groove where that O-ring is located. Use a case knife or similar stiff but fairly thin-edge blade to pop the bezel off (it snaps off). Then gently remove the outer plastic ring, noting carefully how the notches are aligned.
The inner module now can be lifted carefully out - the two 'pushers' will not fall out of the case when you do this. The battery is a 3V lithium CR2025, and you will need a fairly small straight-blade jeweler's or optician's style screwdriver to remove the one screw that holds down the battery bracket - it may be tempting to bend this out of the way to change the battery, but please resist that temptation...
Put the module back in the base, put the ring back over the dial plate, and carefully snap the bezel back in place with its notch aligned as you found it. You might want to check and/or lubricate the O-ring as you do this.
Instructions for initializing the movement are printed inside the case: they list the switch for the 'recessed' button as A, and the pusher as B. In case you didn't note them before closing the case: to reset:
1) push A once. (Display will read "SET"
2) Push A until hands are exactly on 12:00 (and display reads "12"
3) Push B once to start reception
You then follow the standard procedure of putting the watch in a window facing Fort Collins, Colorado, until it picks up the time signal and synchronizes itself.
If you need more assistance with the physical module, there is contact information on it from its manufacturer:
artcoadm@pacific.net.hk
Model number on my module is AR600 WWVB (37.5mm)
Posted on Dec 09, 2010
I have a Fossil JR8096 wrist watch that needs batteries.Does any one know the size?
Take your watch to a jeweler for battery identification and replacement.
Nov 09, 2014 | Fossil JR8096 Wrist Watch
My skagen wrist watch has stopped .why?It has lifetime warranty
Your watch has lifetime warranty - not the battery. Battery should be replaced as soon as it goes flat. Do not leave flat battery in watch - it may leak and destroy the movement. Pop in your nearest watch repair shop and ask to replace battery. Rate me please.
Feb 28, 2011 | Skagen 528SSLG Wrist Watch
Had new battery installed in Howard wrist watch, cannot get the correct time. The date is correct.
You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Jul 17, 2010 | Watches
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
719 people viewed this question
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
