Refrigerators Logo
A
Anonymous Posted on Jun 25, 2014
Dometic RM3663 troubleshooting
Dometic RM3663 will no longer turn on. The lights flash and there is a continuous clicking noise from components on the lower circuit board. It sounds like the system can not fix on to either the 120 volt a/c mode, the gas mode, nor the DC mode.
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Sep 07, 2008
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Anonymous
  • 68 Answers
  • Posted on Mar 24, 2009
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
VtToolMan
Mark
  • 704 Answers
  • Posted on Jul 30, 2009
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 17, 2010
SOURCE: Dometic RM3801. Propane ignition failure.
The older units has a 3 VDC glow coil the newer units have a 12VDC igniter.
Fromwhat your described above the next paragragh is your ignition system.
The igniter control voltages in the newer SPARK type igniters are (+) = 12VDC, (L)= high voltage lead (Spark plug voltage! I.e ruin your meter type voltage), (-)= Ground L is the lead that passes the HV spark from the control unit to the ignitor plate. The L lead should pass one heck of a hit if is workng correctly.
If not look at the HV lead to see if it is grounding out somewhere.
If the gas safety valve is not sensing gas pressure... you will not have 12VDC to the + terminal of the ignition moudule.
With the gas on and you have 12VDC at the ignition module + terminal then most likely the ignition module is bad.
Kelly
Anonymous
  • Posted on Mar 06, 2011
SOURCE: My Dometic rv refrigerator will not light in gas
Mineis the same way. Have you figured out anything yet?
I have a panasonic pt-50lc14, when i push power green light starts flashing then an odd noise sounds periodically from rear of tv "sounds like fan running rough" and green light continues to flash while...
It sounds like a cold solder joint on a component that generates heat. This problem is correctable by a technician and or someone with the ability to troubleshoot on a component level.
Phillips tv power light flashing, clicking noise
There is some shorted component/s at its main digital board. Troubleshooting this stage circuit is a skilled one. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
1helpful
Outdoor 3-Outlet Photocell Timer
Photocell is 'seeing' lights and thinks it's dawn so it turns off.
When lights are off, timer thinks it's night and clicks back on.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
1) Turn photoeye away from lights.
2) Buy new timer since photoeye is first thing to malfunction on cheap Christmas timers.
3) Buy new timer at Lowes, and return defect in new package
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
Domestic RM3663
replace the thermocouple,its the only thing keeping the pilot alight.
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
JVC AV-27820 27
shorted components causes continuous ticking/clicking sound from inside the set! it would really need a shop visit since you have no picture display! if you could trust the service person then it could be worth sending it to a shop!
Top Dometic Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Virgil Watts
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
