There are four polygon motors in side the print head which is located below each drums, the polygon motor is what spreads LASER beam across the length of the drum with the image. To replace you replace all four yellow, magenta, cyan and black, black in particular because that is the reference color for the color print heads
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: how do i set my KonicaMinolta bizhub C203 to copy
set the copier on black then go to utility/counter, user settings then set current settings
SOURCE: how do i replace the
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
C4154:The polygon motor fails to turn stably even
after the lapse of a given period of time after
activating the polygon motor.
• Motor lock signal detects HIGH for a given
period time consecutively during the polygon
motor is rotating
Good Luck and Thank You for using Fixya.
