Efficacious Solutions to Troubleshoot Dell Printer Error 007-340 & 007-341:
Step 1:- Cycle Power on the Dell Printer
§First, turn OFF your Dell printer.
§Then wait for some time at least 15-20 seconds.
§Next, turn the Dell printer ON.
§Determine if the issue still occurs. If yes, then go to the next step.
Step 2:- To Remove PHD Unit
You should try to Remove PHD Unit, by the following way to fix instant fix this issue.
For More Info Get In touch with professional to get proper solution: Fix Dell Printer Error 007-340
Toll-Free No: +1-888-633-7151
SOURCE: I have a Dell W5210n printer that I replaced the
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
(answer previously provided on fixya.com by ramrui)
