Garden Logo
A
Anonymous Posted on Jun 25, 2014
No manual for powerbase 1200 pressure washer - Garden
1helpful
Where can I find a user manual for the Powerbase Xtreme 1800 w power washer?
Go to partsdirect.com. Have your model# , and look for what you need. GOOD LUCK FRIEND.
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Need a powerbase excel router manual
Hi
I'm pierre from malta. Does anyone has a manual for the powerbase excel router 1250w?
New blades for powerbase planer
'Guest' is looking for help with a Powerbase planer - giving him instructions for Makita and DeWalt is hardly likely to help!
I too have a Powerbase and need to find the manual - anyone?
The high pressure lance has sprung a leak can i purchase a new one
If we're talking about a pressure washer, then yes, you can purchase a new lance. Companies usually sell replacement parts, and there are also after-market parts available. You didn't state the brand or model # of the pressure washer, and depending on the brand and model, you may be able to repair the leak. It may be a matter of a worn O ring. If you purchased the washer locally, go back to the store and ask for a repair kit or O ring (s). They will also have lances as well.
Was this helpful?
Top Garden Experts
Jay Finke
Jay Finke
john h
