Computers & Internet Logo
A
Anonymous Posted on Jun 25, 2014
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
Bob Sloan
Level 3:
  • HP Master 2,013 Answers
  • Posted on Jul 30, 2014
Bob Sloan
HP Master
Level 3:
Answers
2013
Questions
Helped
356942
Points
8519
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck
G
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Apr 24, 2008
SOURCE: hd512-2w error code came up
format ur pc..
it will be can fix it..
thanks for using fixya..
good luck..
Anonymous
  • 1605 Answers
  • Posted on Oct 30, 2008
SOURCE: Compaq Presario 5000 PC Desktop MV740
I did think Windows Xp even run on a 64K memory!!
the reason you are getting the error, because the size of meomries.
Here is the thing, lets say you get a working copy of the Windows Xp, and installed it. your machine is going to about half hours to come up, it is going to take longer if you go on the Internet. (5minutes per page).
by the way presario 5000 dated back to Win95. maximum memory is 512MB. which is minimum requirement for WIndows XP.
The cost for upgrade your machine to minimum specification is not really worth. you are going to have to get a new one soon.
the reason for this, is all of the software and Internet web applications are running at a 2007-2008 software, the machine you are using will never be able catch up to it. (todays standard).
My suggestion: if you can affort it, get a new or refurbished one with minimum specification (e-mail me at [email protected], if you want the specs.) you will be much happier.
Anonymous
  • Posted on Mar 17, 2009
SOURCE: Compaq Presario SG1118IL Desktop PC all drivers
VGA DRIVER I WANT
Anonymous
  • Posted on Mar 27, 2010
i wana vga driver of compaq preserio sg1118il
Anonymous
  • Posted on Mar 30, 2010
SOURCE: Windows Did Not Shut Down Properly PC Wont Boot
My pc did not boot, i tried everything open it in Safe Mode, Last Good Know Configuration, Normally etc. I also tried to format it with Windows XP but i did not recognized the CD.
Is it safe to install google chrome update 1.exe
If you got anything from getsoftfree.com, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
Good luck
2helpful
Driver audio HP compaq presario SR5350F pc Intel pentium dual core
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
2answers
I have a compaq presario pc sr5350f and i need a second dvd burner what brand can i use or can i just use any brand
i have the same computer and i just went it and picked oue up that was compatable with my windows and it works great
1helpful
I have a Compaq Presario SR5350F which suddenly has started shutting itself off after being on for about 5 minutes. I ran the test stuff and it didn't show anything wrong with the hard drive or processor....
First thing to do if you have not cleaned the inside of the computer is give it a good cleaning. There may be enough dust inside that it is overheating. Reply if that is not the problem.
1helpful
SR5350F doesn't power on.
Bad Power On switch, (Located behind the Power On button), or bad power supply.
There is a technique to bypass the Power On switch, in order to see if the switch is bad, or the power supply.
Compaq v6000
i want ALL drivers for my compaq presario v3500 model no is V3611AU FOR WINDOW XP PROFs.
Display driver problem
Try this:
START/ right click Computer goto Manage/ click Services
Here are the services I have stopped and disabled. You can right click each service and goto properties to disable them.
readyboost
superfetch
print spooler - must be re-enabled and started if you use a printer
server
computer browser
secondary logon
security center
windows error reporting
windows search
windows firewall - must be re-enabled and started to use windows firewall
Hope that works, and please rate my response if it was helpful.
Thanks and good luck
My laptop turns on itself, i don't know what's causing it. my windows(service pack 2) is fine and running smoothly....
Go to control panel. Power options and there u can see hibernate. enable hibernate and click apply. and come out and go for shut down and there u can see stand by shutdown and restart. then press shift button on keyboard the standby turn on to hibernate. then click hibernate it will shut down the entire system within 10 to 15 Sec try this. and Mail me on this mail ID
[email protected]
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
