Hi
Don't have a Dell, but the link below appears to give a solution that some people have found works for them
http://pcrepairpro10.com/dell-e171f-pcie-fatal-err-b0-d4-f0.php
May be worth trying.
Good luck
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
SOURCE: Dell PowerEdge 2400 - Fatal
For the replacement battery, review the following:
http://www.batteryfuel.com/b-4025-d9161-63002.html
email [email protected] if you plan on scrapping the machine.
SOURCE: Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
