The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in .
F33 error code indicates Pump
drive system error. Try running the unit empty, set to a cold/cold cycle. If
this does not help, you will need to have the unit checked by a service
technician.
Hi.The control is in a "LOCK" feature. Press and hold the Options and Select at the same time until the "LOC" led goes off to take the control out of "LOCK" or to put it into a control "LOCK".
NOTE_ If this standard procedure doesn't release the lock, this will indicate that the main control module is damaged.
until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
