Cell Phones Logo
A
Anonymous Posted on Jun 24, 2014
My phone stopped ringing
The speaker stopped working and the ringer stopped ringing
Aunt Nutmeg
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Aug 15, 2014
Aunt Nutmeg
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
4448
Points
39
You may have turned your volume very low or you may have muted your phone (turned off the ringer). Check your volume and ringer settings.
4 Related Answers
Anonymous
  • Posted on Apr 21, 2008
SOURCE: LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Anonymous
  • Posted on Nov 02, 2008
SOURCE: No ringer volume or speaker phone.
Anonymous
  • Posted on May 16, 2010
SOURCE: blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
fullbar_28
edwin botio
  • 624 Answers
  • Posted on Jun 10, 2010
SOURCE: I have a Nokia 3220 and the ringer is not ringing
clean your buzzer interface first ,if not works change your buzzer its already damage..thanks
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Cant hear vidoes on i phone 5
ringers works on ur phone because ringer use the other speaker to ring it . there is two speaker built on phone and one of ur is not working.
thank u!
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
2helpful
My alarm of 2310 is not currently ringing. It is just showing the stop and snooze buttons. Please reply as early as possible.
The alarms on nokia phones don't ring when the phone is set to silent. Check the ringer mode. Are you sure the phone speaker is working fine?
3answers
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
My external speaker will not work
Hi, what causes the phone not to be able to ring out is due to the ringer inside the phone that allows you to hear a ringing tone and can be used as external speaker too.it's bad.
You will need to replace the ringer inside the phone. When replaced phone will start ringing out and you can hear when it rings out.
have a nice day.
Ringer and speaker stopped working
dear, its hardware problem so go to a certified mobile fone repairer.
Blackberry Bold Speaker problem.
yes it is an hardware problem,you need to replace the ringer and the speaker to enable you to hear music and ringer to work back
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Top Kyocera Cell Phones Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
john h
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
