SOURCE: bunn coffee maker bt10-b is
The heating element inside is problably broken. Thats what mine does. just disconnect it and you will see that cures your problem. You cannot buy parts for this. I have tried already.Junk
SOURCE: Bunn Coffee machine only makes 1/2 pot
Alfaroo is absolutly right on, The thermostat is either set to high or is malfuntioning The water in the tank is boiling and as it expands it has no place to go but right throw the sprayhead tube and into the brew basket.
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
