It would appear there is a blockage (a clog) in the disposal. You might try "FIRST" unplugging the disposal from under the sink. Put a piece of masking tape over the switch to secure it in the "OFF" position. Then remove the black rubber strainer from sink leading down into the disposal. (just pull it out by hand) Clean out all debris by hand. Put the removed debris in the trash can. Run hot water down into the disposal assuring it to drain properly. Do not put items into the disposal which cannot be ground up easily such as potato peelings and meat products.
SOURCE: I have a Badger 5xp & a double sink. When I
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
