My brother in law gave his mother a password protected laptop, she forgot the password and he was killed in iraq. How can I reset, or clear the bios? Ive tried f8 about 500 times, took it apart and removed the CMOS battery, left it out for hours. Can you help?
SOURCE: remove password from award bios on asus laptop
can u mail me a test mail by ur id so tht when ill get the ressoluiton ill mail it to u and thre no such thing as no soltuion if ther e isno solution i have the resoltuion
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: how to clear bios password for my asus laptop i
You will need to disassemble youre laptop and get to the cmos battery. This is located in the bottom right hand corner of the inside of the laptop and looks similar to a watch battery. Do not have your laptop plugged in being charged and have the power shut off. Take out the battery and disassemble the laptop. Leave the battery out for about 30 minutes to reset all bios settings, including your password. This should work and you will then be able to enter into Windows.
SOURCE: how to remove the bios password of Asus eee pc bios password
On the motherboard, near the battery, you will see one of two things.
You may see three posts with a jumper on them. The jumper would be in the normal mode. You should see, next to one of the end pins writing that states CLR or CMR CMOS. Move the jumper to the that position and wait about 20 seconds. Then move the jumper back to the normal position and you should be good to go.
If there is no set of pins with a jumper, there may be two silver squares on the motherboard (very small) that will say something like CLR or RST. Jumping them with a screwdriver when the computer is disconnected from the power will do the same thing as the jumpers.
