SOURCE: kenmore upright freezer
No it is not the timer. You may have an open overload protector at the compressor. Check across the overload for a reading with an ohm meter. If it reads zero it is good, if not replace it.
SOURCE: kenmore upright frost free freezer compressor will not come on...
mlee62599,
You have a freon leak and the coolant leaked out. Perhaps when you mode it down the stairs one of the coils with the freon in it ruptured a tiny hole.
You need an authorized and certified tech for freon.
SOURCE: Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
SOURCE: freezer ok refrigerator not cold we changed the
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
SOURCE: when plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
