The shoe should not be removed. Refer to page 8 of instructions for blade. If the shoe is off or damage refer to instructions for warranty. Based on price it may not be cost effective to pay for shipping.
https://images.homedepot-static.com/catalog/pdfimages/90/9042eb8d-d1a0-413f-b8c3-8721236a2e04.pdf
Put the back part in first. There are usually two little indents on the back wall. Push it back from the front (it should feel "springy" then lock it in in the front. It usually just sits on the front but will kind of lock in place once you've pushed the back part in far enough.
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Remove disc brake caliper from mounting bracket and support with a length of wire or remove sleeve bolt and rotate caliper up and out of the way to remove shoes. Do not allow caliper to hang by the brake line unsupported.
Remove outboard shoe and lining. Use a suitable tool to disengage shoe springs from holes in caliper housing.
Remove inboard shoe and lining, unsnapping shoe spring from piston.
If installing new shoe and linings, bottom piston in caliper bore using large pliers. Take care not to damage piston or piston boot.
Remove bushings from mounting bolt holes in bracket.
To install:
Install new bushings to mounting bolt holes in bracket. Lubricate bushings with silicone grease before installation.
Install inboard shoe and lining by snapping shoe retainer spring into piston. Shoe retainer spring is already staked to the inboard shoe. Shoe must lay flat against piston.
Install outboard shoe and lining by snapping shoe springs into holes in caliper housing. Wear sensor should be at the trailing edge of shoe during forward wheel rotation. Back of shoe must lay flat against caliper.
Install caliper.
Apply approximately 175 lbs. (778 N) of force 3 times to brake pedal to seat linings.
first off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
I am in dire need of the Fisher & Paykel Dryer rack Model # DEGX1. I now have a two year old who loves Mud puddles and I would love to be able to buy the Dryer rack. If you know where I could find one. could you please contact me @ [email protected]
