Question about Kenmore White Electric Stove
Older kenmore electric stove
Used the self cleaning cycle and now the stove won't unlock. How do I unlock a kenmore electric stove after the self cleaning cycle has finished?
    New Friend:
  • 69 Answers
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Posted on Jan 29, 2015
SOURCE:
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
How to clean glass cooktop on Kenmore electric range
Razor blade paint scraper at 45 degree angle, then use non-metallic dish scrubber with stove top cleaning product.
Jun 06, 2014 | Kenmore Elite 44173 30 in. Electric...
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
Nov 18, 2017 | Kenmore 30" Slide-In Electric Range...
How do I know when my stove is done self cleaning?
to get all the detailed instructions
just click this link directly
http://www.applianceaid.com/selfclean5.html
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
thanks.
Nov 11, 2009 | Kenmore Cooktops
How to start the self-cleaning cycle in jenn-air sce30600?
An electric cooktop uses a great deal more electrical energy than a gas cooktop. The electric portion of the gas cooktop runs the electronics (clock, timer, ignitor, oven light, etc.), and these are small electrical loads. An electric cooktop uses more electrical energy cooking a batch of, say, pasta sauce, than a gas cooktop would normally use in a month or two. There just isn't a good comparison as there is such a broad difference in the electrical usage of the two units.
Sep 20, 2009 | Cooktops
Kenmore White Electric Stove Logo
145 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
