Service Manual might help you?
https://discountvending.com/wp-content/uploads/2015/03/Office-Deli.pdf
It has a Sold Out switch.
Q. I've loaded my beverage product chutes and columns to capacity - why does my display say Sold Out? 1. In the can drink chutes, make sure the cans are loaded correctly and firmly pressed against the teeter totter mechanism to fully depress sold out switch. 2. In can drink columns, insure wiring to sold out switch is connected properly. 3. In can drink columns, remove teeter-totter mechanism and inspect sold out switch to insure that the lever is not bent. You may be able to slightly bend this back in place if necessary. 4. Run lane in tE mode to insure motor is being recognized. If the VMC looses recognition to a motor, it defaults to reading sold out. Perform a tE1 test to recapture the motor to the VMC. 5. In the vertical column, insure product is fully depressing the sold out lever. 6. In the vertical column, insure switch lever is resting properly against sold out flap in the lane. 7. Insure wiring is properly connected to sold out switch. If both vertical, and can drink lanes are all reading sold out, inspect main beverage harness for a break in orange wire
is a black and decker 14inch grasshog edger
