I need to download whatever information would be used to install a HP Elite l2201x 21.5 inch LED Backlit LCD Monitor with Windows 8.
HP.com has all you need , they made it and support it why not go there click support or their forum..
you did not need any down load any disk. ever.
model, LM917AA
NO PC told just w8 and w8 can run any monitor and this one at
1920 x 1080 @ 60 Hz (Full HD) , all day long, automatically.
if the PC has a DP port there, does it? if no , oops!
monitors are not PCs, monitors do not compute they are displays only.
the PC can PnP that monitor and the monitor tells the OS what it is and PNP magic sets the limits to above max resolution. or less
by you. a free manual below, and this MON only has a DP port
most PCs do not, so an adapter must be bought.
DP = display port (jacks/cables)
say dvi or hdmi to DP so the monitor can be used.
PnP = plug and Play.
https://www.manualshelf.com/manual/hp/hp-elite-l2201x-21-5-inch-led-backlit-lcd-monitor/hp-elite-l2201x-215-inch-led-backlit-lcd-monitor-user-guide/page-21.html
SOURCE: Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
SOURCE: hp f2105 21
Hold down the menu key on the monitor for 10 seconds. Should get rid of the lock.
My associate is an HP repair tech for 4 years.
SOURCE: I have an EIZO T962 CRT 21 inch monitor with bright screen
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
SOURCE: Have a Hp L1925 lcd monitor that the green power
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: HP f2105 21" LCD Monitor is going to sleep after 2 sec.
Try it on another PC so we can narrow down the problem before taking the monitor apart. Please post back. It can be the setting on your PC, vide card problem, need to narrow down first. I will be working a third one of this model tomorrow and I will upload the pictures of what inside tomorrow.
