Download is different from Install. It does not look like you can purchase and download Cakewalk SONAR 7 Producer directly from Cakewalk. However, to install on a Mac, you either need BootCamp, or a virtual machine (VM) solution such as VMWare, Parallels, or VirtualBox, and a valid Windows 7 or 8 install.
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
I looked all over the Cakewalk website and could find no info pertaining to using sonar 4 with Vista, however I did find a link to e-mail there tech support it is free and they claim a 48 hour responce time here is the link http://www.cakewalk.com/Support/SONAR/SR4.asp
I woll tell you this I am running Vista and have found there are some programs that just wont work with Vista, this is not nessaseraly true for you but just be prepared in case they tell you to upgrade to version 7
