The way to find your ip is to printout the configuration page on your printer. You may need the network configuration report if it has one. Now you know the ip address you need to make sure the printer is set to DHCP which will mean it will automatically assign itself an ip address. Go into the pc and find Add a printer. Tell it its a network printer and it will search for it and find it. The rest is history!
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
go to the driver and print the configuration label, if you see the ip adress, just write the IP adress on the browser and you be abel to check the configuration from the printer, it is possible to change some setings from there.
check ipconfig if ur ip adress is correct
configure Ip address statically but then be carefull that u dont duplicate another Ipadress already on network
make sure gateway ip adress is correct as well as dns server ip adress
try to add urself to the domain
check if your pc name is correct
did you enter proper ip or url in configuration . when cldvr v 101206 opens ther is config button u click that enter same ip adress of dvr. this dvr ip adress you will see in dvr system ip configuration. that ip you have to eneter in config button and than click connection button and eneter passowrd admin and there you go
I think you mean that you configured your router at 198.168.254.254
in that case i would go to your network properties of windows.
set a fixed ip of 198.168.254.x (x= anything between 1 and 253)
set your gateway fixed at 198.168.254.254.
then open the explorer and type the adress of your router. Now you should be able to change the ip of your router and if needed enable DHCP.
if you enable dhcp go to your computer and set it do dynamic adress or get adress from dhcp.
or
set your ip settings of your computer as of it was before.
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
