SOURCE: stuck bit
I HAD THE SAME PROBLEM AND STILL DO FROM TIME TO TIME. I USE THE PROPPER BITS, SO THAT ISNT THE PROBLEM.
WHAT WORKS IN GETTING THEM OUT... JUST TAP THE BIT INTO THE CHUCK AND THEN PULL THE QUICK RELEASE AND THE BIT COMES RIGHT OUT. THE BIT JUST GETS INTO A BIND AND TAPPING THE END FREES IT UP
SOURCE: I have a DEWALT DC920
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
SOURCE: dewalt dc925 chuck is stuck closerd with a hole
We had a dewalt keyless with a bit in it and stuck from where I had gotten it wet. WD-40 did not help.Sprayed PB Blaster in an around the chuck, let it sit for 30 minutes. One good twist with channel locks opened it right up.
SOURCE: my drill bit has stuck in the chuck of my dewalt
I don't think that now your drill machine is in running condition. So, I would like to suggest you that you must be buy new one drill machine. And, if you are looking for any proper source for that so here you can get Dewalt drill machine.
