Question about Jump Start JumpStart 3D Virtual World Quest for The Color Meister
We downloaded this game but the graphics wont display, the entire screen is black. How can I fix this?
My ps3 wont display anything in any area except the settings and it wont turn off completely it will only go to a black screen and the green light will just keep blinking
you are getting Black screen While using your ps3 and nothing else Right .................
if so then dont worry you can fix this easily with the help of repair guide available in net ....... you can download it and solve your problem its a big process but if you do correctly according to the guide then you can fix this....... All the best
Click Here to download guide
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
My s100-s1133 protege will not boot-up. The screen is full of checkard black boxes. Could this be the motherboard and if so, how much for the repair?
This is unfortunate, as that points at a display problem which in my experience with these laptops comes with very little chance of repair.
In my opinion it is caused by overheating of graphics processor due to the portege's relative small build. The fix would require dissasembly of entire laptop and re-soldering of graphics processor. This takes a technician using a microscope equipped station,( my father does this and makes over $40 an hour and I bet his company charges more. It is not cheaper than some new laptop models available today. The non-expensive fix but risky, would be to disassemble board and attempt to re-flow graphics processor connections by heating with heat gun. When I attempted this I lost entire display. My recommendation is to use external monitor if possible, which may prove futile since issue with graphics will likely be visible on that too. good luck
Apr 15, 2010 | Toshiba Portege S100-S1133 Notebook
The screen went black and now it has alot of lines across it
Sounds like a bad video card.A video inverter could cause distorted graphics but usually it turns out to be the graphics card.
Jul 30, 2009 | Computers & Internet
Screen turns black
Consider up gradeing your Power Supply Unit.,Depending upon a low wattage PSU to power significant upgrades ie;High end Graphics Processor Units,is a sure way to a black screen.Check out Power & Cool.com.
Mar 20, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Graphics for games only 1/2 the screen on Sony Viao desktop
Check each game under "OPTIONS" and see if the display is set to 1024X768 or what ever. if it is that high, you may need to drop it back to the 800's.
Also, make sure you have the lastest DirectX drivers from Microsoft.
http://www.microsoft.com/downloads/details.aspx?familyid=9226a611-62fe-4f61-aba1-914185249413&displaylang=en
let me know.
Mastersage......................................................................................
Feb 20, 2009 | Sony VAIO PCV-V210P PC Desktop
Hi...i just installed game left4death....but when i start the game screen is blank....i have tone...just dont have a screen...evrethyng is black...help me... graphic card is asus a9250
Hi there, you may just need to download the latest display drivers for your radeon card... google radeon drivers and you should easily find them.
Dec 16, 2008 | ASUS A9250/TD Radeon 9250, (128 MB)...
Brian lara cricket 07 inadequate graphics card
Check the minimum requirements for the game from the game's cover. Next, check you graphics card to comply. If it falls short, then unfortunately, there are no downloads that can increase the memory/performance of your card. Best solution would be to replace the card compltely..
Nov 13, 2008 | Codemasters Brian Lara International...
Quarter screen display for cd games
I don't suppose the game being on CD has anything to do with it. You don't mention if you are using XP, Vista or what, so advice is general
Several things you should check :
1. on control panel, look at display settings - especially check you don't have multi-display settings (i.e. set to display screen over multiple screens) switched on.
2. click on icon for your graphics card in taskbar if you have one. Check the settings for your graphics card (probably ATI or Nvidia, but could be under name for brand such as Sapphire or XFX)) - also look for multi-display settings here.
Sep 01, 2008 | Fujitsu AMILO Pro V1000 Notebook
Black stripe on screen at boot-up
Maybe its the TV thats the problem maybe its getting to old or something.
Aug 18, 2007 | Sony PlayStation 2 (PS2) Console
Jump Start JumpStart 3D Virtual World Quest for The Color Meister Logo
42 people viewed this question
Top Jump Start Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Jump Start Video Game Console and Game Expert? Answer questions, earn points and help others
