No power/no lights, after power surge/outage. Is there a reset button or fuse that needs to be checked/changed? Is there something else we should check?
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
SOURCE: frigidaire affinity dryer has power but won't start up the cycle
Hi!!! you have a problem with the thermal fuze change it and you will be okay..
SOURCE: need a repiar manual for a Frigidaire FEQ1442ES0 Electric Dry
repairclinic.com
repair manual info
SOURCE: Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the
reason for the 3 prong receptacle)...then you can not properly install
a 4 prong dryer cord to it. You now have 2 choices....either rewire
(assuming that it is a 3 wire supply) the entire run from the dryer
breaker to the outlet location with 4 wire (typically a run of 8/3 with
ground having a black, red, white and bare ground)and install a 4 prong
dryer receptacle to match the configuration of the new dryers
cord.....OR - you can remove the 4 wire cord and replace it with a 3
wire cord....re-using the ground strap - IF it is still in place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
