The receiver protection mechanism is kicking in when viewing movies, but ok when watching normal TV. Also kicks in and shuts down the receiver when setting the surround sound levels.
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
SOURCE: blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
SOURCE: I HAVE AN ONKYO TX
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
SOURCE: TX-DS838 shows protect and then shuts down
yes , Im afraid you have a chip gone , If you open the unit up you'll see a alloy heatsink with 4 to 8 large chips screwed to it , These are the amp drivers , In between these chips you see a smaller one (that is the protect chip),You see when things get a little hot this chip is designed to break sooner that the more expensive main amp chips , In the past ive unsoldered these and still found the amp driver bust too ,dont worry though , maplins or even farnell(cpc) on the web will supply these for less than a tenner..If you wanna test my fix then just unsolder the littlest chip on the main heatsink and it should start to work again but with NO protection(unplug it first before taking it to bits)
