My cat bumped my flat screen monitor that was attached to my northgate desktop computer. My computer is about 8 years old and I bought it from my local staples store. The monitor was cracked and now I have to replace it.
You should have mentioned your Operating System, but I would email or call Newegg, and ask them. http://help.newegg.com/app/home/site/US#ContactUsTab
SOURCE: Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
SOURCE: desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
SOURCE: Dell Desktop DX270 doesn't work with LG w2052TQ monitor...
A Dell Optiplex GX270 can have either on on-board VGA integrated graphics controller or an expansion graphics controller. If an expansion card is installed, the onboard graphics is disabled.
So first, ensure that the VGA cable is connected to the correct graphics connection (If there is an expansion slot with a video connector, ten you must use that connection)
If connected to the correct port on the system, next ensure that the input select for the monitor is either set to autoselect or ANALOG
Last ensure that the display resolution of the graphics adapter will support the new monitor.
SOURCE: AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
SOURCE: how to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
