SOURCE: My Bocsh WFL washing machine wont start any programmes
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: How do I remove the brushes from a bocsh washing
You need to remove the motor from the washer, undo the 2 screws securing motor, unplug the motor lead, remove the earth wire, the brushes are located at the opposite end to the motor pulley.
SOURCE: After 20 minutes of washing
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more... The E13 error indicates a drain or pump error,(drain time exceeded) however the door typically locks as a result of the unit failing to drain, so....
1. **Unplug the washer from the wall or turn off the breaker before attempting any repairs**
2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)try a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open, unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets". Good luck ! **NOTE:too much "He" detergent or the use of non-He detergent can also cause too many suds which are opposition to proper operation of these machines.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. (Sorry about the post, I'm still adapting to this "htc" windows 7 phone after having an iphone for 2years...very tricky lol )
Thank you for choosing to "FixYa".
Regards,
Macmarkus :)
SOURCE: THE bOSCH 300 SERIES WASHING
Hello, welcome to FixYa.
The E13 error code on most series Bosch including the "Nexxt" series washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to extremely sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
