Fax machines can be set to store documents, print docs or do both. If you set it to only print received faxes, it will try to print and give you some kind of error it if fails (e.g. no paper). Did you get an error? if not it either is set to store and not print, or it didnt store it and you have lost it. From the menus on the Epson, look for where items may be stored e.g. 'store' or 'mailbox' and check if there is any doc in there.
Can I fax using Magic Jack?
This is a
popular question. They do not support faxes, but the answer is yes. You
may need to do some tweaking. However, not much tweaking. First, turn
off error correction on your fax machine or program. Then, set the fax
machine or program to use the slowest speed available. The slowest speed
will ensure a fax goes through. You may increase later to find the
highest speed at which a fax can be received.
If you look up your device on Google which will take you to the brand name website. You will find the troubleshooting guide, this will walk you through how to make sure your faxes send and receive without error. You'll have to make sure everything is set up properly.
your computer has to be set to answer the phone so it receives the data and sends it to your printer. unless the data is demodulated via the modem or other demodulating softwarew .. it cannot be printed and or viewed. check your settings in the "printers and faxes area of the control panel to verify proper settings or make any necessary changes.
Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
Make sure that your recipient's fax machine is turned on and working.
If you connected the Epson Stylus CX to a DSL phone line, you must
install a DSL filter to the line or you won't be able to fax. Contact
your DSL provider for the necessary filter.
If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
Follow these steps to turn off the ECM setting:
Press Setup.
Select Fax Settings, then press OK. You see this screen:
Select Communication, then press OK.
Press and select ECM. Then press and set it to Off.
Press OK.
RECEIVING
Try the following if you can't receive a fax:
To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
Make sure paper is loaded.
Press Setup.
Select Communication then press OK.
