Canon MX300 Office All-In-One Printer Logo
A
Anonymous Posted on Jun 23, 2014
The machine is telling me to open the paper output tray and the code is 1250
Stephen Gillmore
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 24, 2014
Stephen Gillmore
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1075
Points
7
The fix for that error simply says to open the door by hand. If that doesn't fix the issue you need to contact a service center.
1 Related Answer
hattinghbr
Rudi hattingh
  • 214 Answers
  • Posted on Nov 04, 2011
SOURCE: error 1250
look for a small sensor on you right hand side. it tell the m/c if it is open or close. it migit be stuck.
2helpful
Canon printer error code 1256
Error Code: 1256 Cause: The paper output tray is closed or it has not opened.
Action: Confirm that there are no materials preventing the paper output tray from moving and that the paper cassette is inserted properly.
Open the paper output tray, then tap OK on the touch screen.
Important
  • Do not close the paper output tray while the machine is in operation.
2answers
What is code error e03
Printers & Copiers
Code error E03
3helpful
Error 1250
2answers
Xerox 7300 paper jam A 10 error code jam telling me to open top tray and I've looked at the machine inside out and cannot find any scraps of paper or any location where there is any traces of paper being...
There is most likely a small piece of paper in the rollers take out Tonor and any parts that will come out with out having to use any tools. then spray with a can of air in all the rollers.
Chris Thrash
B52Computers
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
1helpful
2answers
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
2helpful
2answers
C0920
Paper Tray Lift error code. Check and reload all the paper in all the trays. Power off then on to reset. If this does not solve the code then pull out all paper trays. Reset machine leaving alll trays OPEN. Close the trays 1 at a time waiting 30 seconds between each tray closing. If the code comes back after closing a tray then that will tell you which tray has the problem. You can leave that tray open so you can use the machine and also you can check that tray more closely.
PIXMA ip8500 not printing
i have a pixma ip4300 i keep getting the error number 1250 "paper output try is closed" but infact its is open i have tried opening and closing and restarting and everything else i can think of. any ideas of what to do?
Sharp al-1250 wont switch from tray 1 leter to tray 2 legal when printing
On the control panel there should be a button that either says paper select or looks like a bucket with lines in press this and the machine will change paper trays.
Thanks J
old marine
old marine
ZJ Limited
ZJ Limited
