SOURCE: Automatic Grind not working
My grinder was not working properly, because the blade was not rotating freely. So we carefully chipped away some caked on coffee residue. Then it worked for awhile, but started to sound weird and only partially grind the coffee. So we applied a small amount of vegetable oil to the blade and let it seep down a little, and that was very succcessful! Just needed a lube job!
chrisnap49
SOURCE: Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
SOURCE: Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
SOURCE: I Have a Cuisinart Automatic
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
SOURCE: Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
Put the whole brewer in your refrigerator freezer for 2 hours. The coffee basket then will come off. Take the entire brewer unit to your shower and rinse it thoroughly. Now look at the basket and where it goes on the brewer. You will see a little spindle and 2 sets of helical gears. Spread white lithium lube on the spindle and the gears. It won't get in your coffee because it's nowhere near the water flow. This should solve the stuck basket problem.
