Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Here is a link to your printers manual. It has troubleshooting in it and explains what the error means when you see the picture of the sun with the ink drop & exclamation point blinking. It also has instructions on how to fix the error and stop the blinking.
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
The 1710 only has three options: two rings, four rings, and toll saver. There's a switch on the back that controls this.
The toll saver answers on the second ring if there are new messages, on the fourth when there aren't. This allows you to call in from a remote phone. If there are messages waiting, it'll answer on the second ring. If it rings at least three times, there are no new messages and you can hang up before you get charged for the call.
Unfortunately there are no settings for more than four rings. Sorry if that wasn't the answer you wanted to see, but there it is.
