Question about Frigidaire FAC126P1 wall/window Air Conditioner
My frigidaire window a/c has a drain hole but it doesn't drain and it is not collecting any water near the coils. Why is it not draining?
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand your Frigidaire air conditioner, model# FAC126P1, is not draining water or collecting water near the coils. When your air conditioner was installed, you would have wanted to make sure that the top rail and sliding panels at each side were offset to provide the proper pitch to the rear of (5/16"). This is necessary for proper condensed water utilization and drainage. If you are not using the Side Panels for any reason, this pitch to the rear must be maintained! I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on Jun 30, 2014
SOURCE:
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
icemelts
  • 246 Answers
SOURCE: The drain hole is in the window sill, not the back
I'm not sure why that drain hole is located where it is - but in any case - you're going to have to plug the existing hole and re-drill another drain hole at the back of the unit.
I would plug the unwanted hole with a 'liquid steel material,' i.e. JB Weld or something similar.
Note: be careful when re-drilling the new drain hole and don't drill a hole in your condenser.
good luck!
Posted on May 04, 2010
  • 2976 Answers
SOURCE: My FAC104 P1A window air conditioner does NOT
Some don't have a drain hole anymore. As long as you have it tilted slightly, any excess water will drain out. If your house or room feels good, it's working. It won't pull moisture out of the air if the air has already been dehumidified.
Posted on Jun 28, 2010
wise_jf
  • 66 Answers
SOURCE: there is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
Posted on Jul 14, 2010
roniecon
  • 6927 Answers
SOURCE: THE DRAIN HOLE FOR MY FRIDGIDAIRE AIR CONDITIONER
You will have to remove the unit fro the window,and take it outside and remove the cover,unless the sheel remains in the window,and use a water hose to clean all the debris out and clear the drain,this really needs to be done every year,also,make sure the tilt on the unit is enough for the water to drain outside,not in,if this was at all helpful,please rate thank you.
Posted on Jul 18, 2010
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
My freezer is collecting water in the bottom just below coils how do i repair
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRS6R4EQ4 is collecting water in the bottom of the freezer, below the coils. I also see that you think the drain is clogged. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water is collecting. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
I have a goldstar air conditioner thats throwing water
The problem you're having can be the result of 2 tings.
1. The drain hole in the drip pan under the unit is clogged. The hole should be located near the rear of
the unit. It can be hard to find at times, as the clog will bled in with the hole.
2. The rear of the unit does not have enough downward tilt. Which allows the collected water to flow to
the drain hole. The general rule of thumb is 1/4" to 1/2" downward tilt at the rear of the unit.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Frigidaire FAC126P1 wall/window Air...
Need to know if I can connect a drain hose/tube to my air conditioner model # FAX054-P7A1. I'm having a problem with water collecting in the window sill/track
Hello, the first thing is make sure the AC is tilted a bit in the window, if it is level the water will collect toward the front of the unit and drip inside. Second if there is a drain hole on tne unit then you can connect a hose to it and let it drain. However if there is no drain hole then the unit uses tne fan blade to splash the water on the condenser and since the condenser is warm/hot it will condense the water.
Jun 08, 2011 | Frigidaire FAX054P7A Wall/Window Air...
When automatic defrost operates, the water created collects inside the bottom of the refrigerator rather than draining into the exterior pan. Two different service men cleaned the exterior drain and coils.
Inside the freezer where the drain hole is is getting blocked with ice. If you have had it cleared twice already and the problem persist. The make something called a drain heater. This piece of metal wraps around the defrost heater and the sets down in the drain line heating everytime the heater does and causing any water that make have collected there to thaw and run out instead of freezing up and overflowing into your freezer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 17, 2010 | Frigidaire Refrigerators
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
My ac window unit does not seem to have any obvious drain hole or plug
Jun 21, 2009 | Frigidaire FAC126P1 wall/window Air...
Water collecting at the bottom of the freezer. Seems to be comming from vent that protects the coils. I think I have a blockage some where. It's a side by side Frigidaire model FRS24WNGWO with an ice...
your drain hole under your evaporator has some kind of restriction. remove rear panel in freezer section and look for drain hole. take a hanger and unravel it and poke it through the hole
Jun 21, 2009 | Frigidaire Refrigerators
Jun 09, 2009 | Frigidaire FAC126P1 wall/window Air...
Frigidaire side by side freezer- water which turns to ice is collecting at the bottom of the freezer - drain hole at the back / lower part of the freezer appears to get frozen - causing the water / ice...
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
Aug 11, 2008 | Frigidaire Refrigerators
Frigidaire FAC126P1 wall/window Air Conditioner Logo
233 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
