Water will not drain out and now washer will not fill. shows error code 21
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Drain Hose
also check pump for clog.
Read more : http://www.ehow.com/info_12102450_f21-error-whirlpool-duet-washing-machine.html
Testimonial: "Thanks Dean! I did try restarting it but will give disconnecting the hose a try- I hate to just throw it away because I feel like it's just clogged somewhere.. You're suggestion makes me feel like I can figure it out :)"
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
