Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to factory reset a bizhub 350 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • 1 more comment
  • JMJr Jun 23, 2014
    Hi Sandy , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Are you trying to reset the password?
  • Sandy
    Sandy Jun 24, 2014
    No, just want to do a cold reset to set everything back to factory settings.
  • Norman  J Weimar Jr
    Norman J Weimar Jr Dec 28, 2015
    Why the reset of the machine code issue?
How to reset bizhub 350 to factory settings
why to factory setting? problem with memory? code or certain problem?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How reset konica minolta bizhub 350 ?
reset what on the bh 350
May 19, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Mac address for bizhub 161f
are the print driver installed properly was a ip address given to the machine
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Make a new from the old..
Please explain reset all programs what programs on a Bizhub 350 ?
Feb 20, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How do you do a hard reset on a Bizhub c350? Thanks.
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 doesn't print at night.
Check the driver, you should have availability.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Aug 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Factory reset
Here is the user's guide, factory reset is on page 2-29 ( page 85 in the bottom reader bar:
http://www.kn.nl/data/handleiding/177367/User%20manual%20bizhub%20250-350.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
394 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
