Casio CTK810 61 Key Keyboard Logo
A
Anonymous Posted on Jun 23, 2014
Can i make casio ctk1100 compatible with pro tools
cornell savage
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 24, 2014
cornell savage
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
108
Points
Yes but your have to buy the disk. from pro tool to make it work. you cannot use the simple protool be cause it give you 15 day to use it and than it will expire. and plus your not going to get all of the conponet from try verison.
1helpful
3answers
Can a Casio Ct-636 support a sustain pedal?
No you can't as our PROPER Expert Cindy says.
Casio Ct-636 does not support any sustain pedals.Amazon.comhttps://www.amazon.com > ask > questions
A: Casio Ct-636 does not support any sustain pedals.
The other 'Contributor' probably saw this
CT-S1000V - SupportCasio https://support.casio.com > manualPDF
This Digital Keyboard does not come with a pedal unit. • You can use the PEDAL1 jack to connect an optional (SP-3, SP-20) sustain pedal. You can use the.
Mar 13, 2023 • Casio Music
Is there any way to connect my casio ctk1100 to a laptop??
Yes. But it depends which connectors you have on your laptop. If you have a small (3.5mm) stereo jack input, then you need one cable with a small stereo 3.5mm jack on one side and a big stereo 6,3mm jack on the other side. (Take a look at the picture below).
Then you plug in side with a small stereo jack in your laptop "line in" input and other side of the cable with a big stereo jack to your Casio CTK-1100 Phones/Output plug on a keyboards rear side...
Be sure to adjust the volume on both the Casio (output volume) and laptop (input volume)...
Cheers!
Mar 01, 2017 • Casio Music
1helpful
Is there a sustaining pedal Casio keyboard model ctk 401
Generally, all Casio sustain pedals are compatible with all their keyboards, but i normally recomend the SP-20. SP 20 Pedals Products CASIO
Apr 22, 2016 • Pedal Music
1helpful
2answers
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 • Casio Music
What kind of adapter do i use for my keyboard Casio ca-110
if you don't want to wait, you can go to radio shack and get a universal adapter for a bit more, but it should work no problem.
http://www.amazon.com/HQRP-Adapter-compatible-Keyboards-Replacement/dp/B004TXDL3C
May 26, 2012 • Casio Music
2answers
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
What software do i need to record from keyboard to pc
You can use FL studio it's easy to adjust and easy to work with. Also you can find more help then maybe any other software out there. Also you can find instructions on Youtube how to hook it up. Cake walk is another one, I think adobe audition can too use to be Cool Edit. You can try pro-tools but it's difficult, at least for me it was and finally Sony Acid does it too. Well good luck.
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
