Question about Akai LCT2060 Television
How do i clean off buttons inside a tv remote?
Some buttons no longer work.
    New Friend:
    Problem Solver:
  • 7 Answers
Try using a universal remote
Posted on Nov 26, 2014
6ya staff
SOURCE:
The power on/off button on the remote control works but the channel & volume buttons no longer work
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
IR sensor and side buttons don't work
Check the remote control first for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside the battery compartment, for any dust or rust accumulated. If you wish to know more about how to check and clean a remote control, check this link. If remote control is found OK, check and replace the infrared sensor inside the TV. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 26, 2013 | Philips 27PT543S 27" TV
Philips TV 42PFL7403D/F7 Remote no longer controls Volume & ON/OFF
you can start with opening the remote control and clean the buttons on your remote control. don't use any aceton based products. there can be some grease on the buttons.
if you used the on/off and volume more then the other buttons.
Dec 19, 2017 | Philips Televison & Video
MY REMOTE NO LONGER WORKS MY TV BUT THE BUTTONS ON THE SIDE DO WORK
Have the actual remote itself tested---most shops will do it for free--if remote is bad you know and if tests good suspect the remote receiver in the set on the front is bad.
The last possible reason is some sets have a lockout feature that disables the remote feature inside the TV---not real common but no unheard.
Sep 04, 2012 | Westinghouse SK-26H590D Television
My remote is no longer working to my insignia 42" tv
First verify whether its an issue with the tv or the remote. If you have a digital camera or a phone with a camera point it towards the front of the remote control when you are hitting a button. a red light should blink. This infrared light can't be seen by the human eye but it can through a camera. If you can see it then it's an issue with the tv which would be more costly to repair. If it's the remote try new batteries or purchase a direct replacement or universal remote.
thank you,
Lee
Aug 22, 2011 | Televison & Video
Remote no longer controls tv set. Changed batteries and cleaned contacts in remote. . also in the Dish network remote which now no longer works with the set either.
Sounds like you may of changed the frequency of the set or the remote? There may be a button somewhere on the remote or the tv to change. Or possibly there is interfearance from something, have you recently installed something that is wireless like a cordless phone maybe?
Steven Cumming
stevencumming@hotmail.com
Please leave feedback :-)
Jun 05, 2011 | Televison & Video
My remote 00053a no longer works my tv
I assume that you tried replacing with fresh batteries, the battery contacts are clean?
Universal remotes are available to replace yours. You have to type in a product code for the type of TV.
Feb 05, 2010 | Samsung TV Remote Control
We have 2 Sylvania TV's. The remotes work on one TV but the other TV no longer recognizes the remotes. It gradually seemed to lose reception of the signal from the remote. Any ideas?
The tv has a infared remote eye located at the front panel. It is possible that the remote eye sensor has gone bad. You could try cleaning the remote eye lens. There might be debris that got inside the remote eye housing and is blocking the sensor. You could also try installing fresh batteries in the remote.
Sep 26, 2009 | Sylvania SRT2319 TV
Remote Control #1 will no longer control TV
Remove batteries from remote and put in fresh batteries, this will reset the remote.
Feb 08, 2009 | DISH Network IR Remote Control
On / off
I suggest you to take out the remote control batteries to discard that as the problem.
Try working the TV without remote controller to see all the functions working and if everything works ok without the remote then you may have a broken remote controller.
As I can conclude with your pretty small description, you may have some remote buttons stuck and maybe humidity or plain fluids into the remote controller circuits causing false button activations in buttons like the ON/OFF, or PIP, or RECALL.
You can try open the remote and clean any dirt and humidity inside, specially taking care of the rubber buttons pad and its black touch pads behind each button. also the circuit board and the golden/black threads where the pads touch the board.
Also if you note a broken battery, clean any battery fluids inside the remote as these liquids are very corrosive for the circuits.
Good Luck...
Oct 17, 2007 | RCA F32632SB 32" TV
Akai LCT2060 Television Logo
26 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
