Bulova Marine Star 98G86 Wrist Watch Logo
A
Anonymous Posted on Jun 23, 2014
How does the alarm work? - Bulova Marine Star 98G86 Wrist Watch
I have a timex expedition. Eventhough the battery is new, the alarm and the beep function does not work properly. I have to shake the watch to make it work
If your Timex Expedition watch alarm and beep function are not working properly, even with a new battery, it could be caused by a few different things. Here are some steps you can try to troubleshoot the issue:
  1. Check the alarm settings: Make sure the alarm is turned on and set to the correct time. Also, check that the alarm is set to the correct mode, such as daily or weekly.
  2. Check the watch's manual: Refer to the instruction manual that came with your watch to see if there are any specific instructions for setting the alarm or beep function.
  3. Check the vibration function: If the vibration function of the watch is not working, it could cause the alarm and beep to not function properly. Try resetting the watch or contacting Timex for assistance.
  4. Check for physical damage: Inspect the watch for any physical damage such as a cracked or broken case, or a damaged alarm switch.
  5. Check for water damage: If the watch has been exposed to water, it could cause damage to the electronic components. If water has entered the watch, it is best to take it to a professional watch repair center for service.
  6. Check if the watch have a warranty: If the watch is still under warranty, you should contact the manufacturer for service or repair.
How do I turn up the volume on timex ironman watch alarm?
If the spring is missing, you can wind a temporary one out of extremely fine coil wire around a sewing needle . If watch case is closed and alarm does not sound try stretching the coil slightly. If alarm comes on keep stretching coil a bit further to see if alarm gets louder. Similarly, coil may be too long if alarm does not go on. Then gently squeeze coil a little smaller and put case back together again to check alarm. If it is too soft then squeeze the coil a little more.
There is definitely a sweet spot for coil length whether hand made or store bought. Lots of fiddling but it works.
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 • Watches
7helpful
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
138helpful
2answers
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
2helpful
Need help setting the alarm
yes,I have a diffrent watch but it might still work.First you have to hold mode for 5 seconds and then the alarm will show up and you set it if it dose not work tell me.
Mar 29, 2009 • Watches
4helpful
Sector 250 Chronograph Alarm
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
enjoy the watch!
1helpful
Citzen Aqualand 1997 Divers watch..Great condition!!
the alarm works by a spring rubing on the back of the base plate of the watch if this spring is bent or not in the right place the alarm will not work
8helpful
5answers
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
