Husqvarna New Zero Turn Lawn Mower RZ4623 Logo
A
Anonymous Posted on Jun 22, 2014
Husqvarna New Zero Turn Lawn Mower RZ4623 will not go into gear
Richard Haynes
Level 3:
Master:
  • Husqvarna Master 673 Answers
  • Posted on Dec 12, 2017
Richard Haynes
Husqvarna Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208373
Points
1403
Not sure the problem, there are no gears on the drive system. This uses Hydro drive wheel units. If the belt is on and in good shape, check the lever linkage.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 22, 2009
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Anonymous
  • 109 Answers
  • Posted on May 03, 2009
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Anonymous
  • 8 Answers
  • Posted on May 21, 2010
SOURCE: How can I tell what year my husqvarna lawn mower was made ?
Write down your serial number. Call local dealer and have them look up the year. You can also Google your serial number sometime it will give a year of the mower or range of years.
Anonymous
  • 3911 Answers
  • Posted on Jun 01, 2010
SOURCE: i cant replace the deck belt on my husqvarna ct151 lawn mower
The manual shows how the belts are put on, if you do not have one they may be purchased through dealers or small engine repair shops or online. On mine there is also a little diagram on the top of the mower deck. Another way to check is find an identical one that is functional and look at its belt. There are only so many ways it could fit and these are all made by just one or two manufacturers so there is not much variance.
Tim Whalen
  • 3076 Answers
  • Posted on May 22, 2011
SOURCE: need a belt diagram for
ttp://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CHUS%5Cimages%5C90%5C35%5C0019.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=23
Diagram of drive belt for husqvarna rz4623
Hi Willard, The link below is a web page with the diagram for your lawn mower.......CHEERS..
Diagram of drive belt for husqvarna rz4623 Google Search
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Model rz4623 zero turn deck belt is jumping a lot
see if belt has burn spots in it that will cause it to jump excessively
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
