How to calculate 8!/(5!3!)?
For small numbers (8,5,3) you can use the factorial function key (I will tell you later how to access it) and enter 8! divided by 5!, divided by 3! For numbers greater than or equal to 70 you cannot calculate the factorial: the result is too large for the calculator's memory.
However the formula you wrote is an instance of a combination 8C5 or 8C3 (they have the same value.
Most scientific calculator have three functions: the n Factorial n!, the Combination function nCr and the permutation function nPr.
- Turn Calculator ON
- Select the Run icon and press EXE.
- In Run Screen Press the OPTN key
- Press F6> to pan to the other tabs
- Press F3:Prob
The first tab (F1) is marked x!.
That is the factorial.The tab (F2) is marked nPr is for the
permutationsThe tab (F3) is marked nCr and it corresponds to the
combinations.
To use
nPr or nCr you enter the larger number n, you press the F key under nPr or nCr. If you press F2 you see a fat P, if you press F3 you see a fat C. Complete by entering the value of r (the smaller number)
If your problem corresponds to Select 8 objects, 5 at a time regardless or order (combinations) you type 8 F3 5 and EXE Result is 56.
