Pool & Spa Logo
A
Anonymous Posted on Nov 09, 2017
Lazy spa pump leaking from the base
Hi my lazy spa pump is leaking water from the base, all working fine apart from this, i have read it could be the o-ring but dont know where this is , even though i have had a part and checked all rings etec all look ok, can any one help as it cant be more tha a seal as the pump workis fine etc apart from the leak at bottom of pump
5 Related Answers
Pierre Laplante
  • 2061 Answers
  • Posted on Feb 25, 2008
SOURCE: leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Anonymous
  • 324 Answers
  • Posted on Nov 05, 2008
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Anonymous
  • 5 Answers
  • Posted on Dec 21, 2008
SOURCE: Whirlpool model WTW6600SW1
you'll need to pull away the washing machine. then turn it around. theres that big steel plate with a bunch of quarter inch screws. remove that. Then youll be able to find where its leaking. There will be a drain pump and another pump that is for pumping the water back into the machine. There will hoses and most likely ull just have to adjust those hose clamps. Its a little bit of a pain but just get some channelocks and squeeze them down with one hand and with the other push it back where it needs to go. Ive been working on my gf's washer (same one) and i think its a piece of ****! because its only 2 years old and already the motor is out on it. so do yourself a favor and dont be hard on it. dont wash anything to large it it! just a piece of advice cause im seeing all kinds of ppl online that are having trouble with it after 18 months, 20 months, etc.
Anonymous
  • 22 Answers
  • Posted on Feb 21, 2009
SOURCE: My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Anonymous
  • 3 Answers
  • Posted on Mar 12, 2009
SOURCE: Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
I just refilled my Cancun lazy spa and it won't heat past 38deggrees... please help???
If your Cancun lazy spa is not heating past 38 degrees Celsius (100.4 degrees Fahrenheit), there could be several reasons for this issue. Here are some troubleshooting steps you can try to resolve the problem:
  1. Check Water Circulation: Ensure that the water is circulating properly in the lazy spa. Make sure the water pump is functioning correctly and there are no blockages in the water flow.
  2. Water Level: Check the water level in the lazy spa. If the water level is too low, it can affect the heating process. Ensure that the water level is above the minimum level required for proper heating.
  3. Heater Unit: The heater unit may be malfunctioning or not working at its full capacity. Check for any error codes or indicators on the control panel. If there are error codes, consult the user manual to determine the issue.
  4. Temperature Sensor: There might be a problem with the temperature sensor. If the sensor is not accurately reading the water temperature, it could prevent the lazy spa from heating properly. You might need to replace the temperature sensor if it's faulty.
  5. Electrical Connections: Ensure that all electrical connections are secure and there are no loose wires. Faulty connections can lead to heating issues.
  6. Power Supply: Make sure the lazy spa is receiving the correct power supply. It should be plugged into a dedicated power outlet that can handle the load required for heating the water.
  7. Ambient Temperature: Cold weather can impact the ability of the lazy spa to heat up efficiently. If the outside temperature is significantly colder than the desired water temperature, the heater might struggle to maintain higher temperatures.
  8. Thermal Blanket or Cover: Use a thermal blanket or cover designed for lazy spas to help retain heat. This can prevent heat loss and assist in maintaining the desired temperature.
  9. Filters and Water Quality: Clean the filters and ensure the water is well-balanced and properly treated. Poor water quality can affect the heating process.
  10. Timer Settings: Check the timer settings on the control panel. Sometimes, the spa might be set to a lower temperature or a timer might be restricting the heating.
  11. Reset: Try resetting the lazy spa by turning it off, waiting for a few minutes, and then turning it back on. This can sometimes resolve minor issues.
1helpful
Hi I have a lazy spa Miami it’s 30 days old and I’ve only ever taken the pump of once but the big thick pipe has started to leak water is piece c it’s only a trickle at the moment it’s not stuck in the...
did you narrow down what is leaking if seal is it tight enought or sitting wrong or damaged is it the pipe cracked hole etc or is it the spa liner / connection --and if told to bring back to shop why not doing so
Jul 26, 2018 • Pool & Spa
Hi my lazy spa paris is leaking water I think from the non return valve best way say it's un fixable please helo
IS it leaking from valve and is teck telling you that valve in not fixable/ serviceable and will need replacement --because if leak is cracked plastic line thats repairable
May 30, 2018 • Pool & Spa
1helpful
Hi I have a lazy spa pump?(egg shape)it’s started with a leak coming out at bottom,is it easy enough to take apart?and is there a common fault?thanks
indicates a shaft seal problem
repair requires mechanical knowledge and tools so take it to a pump shop for repairs
Apr 30, 2018 • Pool & Spa
2answers
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 • Pool & Spa
2answers
Lay-Z-Spa e01 error
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Jun 02, 2017 • Pool & Spa
1helpful
Lazy-spa hot tub saysE03 what to do
E.0.3. The pump’s thermometer reads the water temperature below 4°C (40°F)
1. The water temperature is lower than 4°C (40°F). 1. The spa is not designed to operate with water temperatures lower than 4?C (40°F). Please unplug the pump and move to a warmer ambient temperature. The pump should only be restarted when the water temperature reaches 6°C (43°F).
Dec 28, 2016 • Pool & Spa
Bestway Lay-Z-Spa
We sell the Bestway Lazy-Spa however we do not sell anything other than the replacement filter so I cannot tell you what is all included with that part number.
I would suggest you contact the store you purchased the spa from to determine the contents of the replacement item.
Rod
US Parts Center
Feb 12, 2014 • Pool & Spa
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
