Vizio 60" E601I-A3 Full HD LED-LCD TV Logo
C
Chris Cipollone Posted on Dec 11, 2017
Why do I have green vertical lines on my vizio E601i-A3E tv
Why is my screen displaying vertical green lines in place of black or shaded areas on the picture? There is also a very predominate solid green vertical line running from the top to the bottom, on the right side of the screen. What could cause these manifestations of excess green to display? How can they be fixed?
5 Related Answers
Anonymous
  • 142 Answers
  • Posted on Apr 09, 2008
SOURCE: Vizio L37 37" LCD screen screen is cracked.
I agree your screen is cracked. It's smooth to the touch because you're not actually touching the LCD section of the screen, just the protective coating. The advantage of owning an LCD TV over plasma... you can replace the screen either by going to the manufacturer or some place like e-bay. It's not a difficult thing to do if you take your time and pay attention to the details.
Good Luck
Anonymous
  • 61 Answers
  • Posted on Sep 20, 2008
SOURCE: Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
Anonymous
  • 56 Answers
  • Posted on Feb 16, 2009
SOURCE: visio 42 hd plasma tv 1/2 the display goes out
Replace Y drive should solve the problem.
Anonymous
  • Posted on Feb 18, 2009
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
1helpful
VERTICAL GREEN LINE ON TV? VISIO E601i-A3E
vertical lines are the result of a bad connection at either one of the cables connecting the LCD screen to the driver board OR it is a failure of the edge of the LCD screen at one of the many micro connections that are soldered. You can tell a lot by gently pressing at the edge of the screen at the top and then bottom and if it goes away with pressure it is the lcd and if not, you need to check the cables and connections.
Turn the TV on black and gray vertical lines going across the screen (like pen stripes) and can only be seen in the black or dark areas after 10-30 minutes they disappear and the screen is fine.
In most of the case, the problem is a defective data buffer IC located on the flex cable between the LCD panel & the panel buffer board, this problem can't be repaired, you have to replace the panel
My tv is Vizio E601I-A3E. thereis no display ...how can i fix it
Yes but only if you have skills in electronic parts testing procedures and a DVOM meter and the repair manual for the set.
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
My vizio e601i-a3e doesnt come on, no led , checked power and the wall and it is good
Go to you tube type in your question and you should get the video you need to sort out your problem .
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
My 60" Vizio LED TV has green shades where ever the black should be and it has vertical thin lines
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
My Vizio SV470XVT1A, when turned on has vertical green lines, when playing a movie the lighter shades of color are good but all the dark shades have green vertical lines through them. I am trying to fidure...
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
