How do I open the spool to refill the line?
SOURCE: lose gas line poulan weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines.
(HINT):
when feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
Jim
SOURCE: Fetherlight xt200 fuel line connections
The
other
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
If you need further assistance, just let me know.
Jim
SOURCE: weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The
next time you run the trimmer and it starts to die, loosen the gas
cap. If it starts running again, then you know that it's a clogged gas
cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
SOURCE: Can,t prime fuel with primer ball on my weed eater
sounds like it has gotten dirt in it, flush lines and tank with brake cleaner, remove primer bulb usually 4 screws and clean under there too reassemble and try again fixes most of the time
SOURCE: Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
