Canon MP610 Photo All-In-One Printer Logo
E
Edwin Posted on Jun 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink Absorber reset software
Ink absorber full
Lawrence Oravetz
Level 3:
  • Canon Master 10,558 Answers
  • Posted on Jun 24, 2014
Lawrence Oravetz
Canon Master
Level 3:
Answers
10558
Questions
Helped
2697441
Points
29284
When the ink cartridge is parked there is a pad that absorbs the ink when the head cleaning routine is run. Clean this out and the message will go away.
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
1helpful
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
2helpful
INK ABSORBER FULL
Your waste ink absorber is FULL. So you need to replace your waste ink absorber to the new one.
This problem can not be solved by the user. You must take or send it to a service centre, where a technician will remove the old ink absorber, clean up any internal ink mess and enter a reset code to clear the "ink absorber full" condition.
Ink waste absorber is nearly full. What do I do?
You need to reset it.
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
7helpful
2answers
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
2helpful
Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
Ink absorber full
you have to reset the waste ink counter of the printer, for this download the software like IP tools, then reset it,
like it or not please rate it
Ink tank absorber full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Do vote if this helps ... Cheers :)
old marine
old marine
ZJ Limited
ZJ Limited
