Our deep fryer keeps bubbling up and this is with new oil and just cleaned out
Hi there.
If the bubbles come up after loading products on fryer, check the product load quantity and reduce as needed so oil will not overflow. Bubbles came from the water content of the product; more water inside the product, the more bubbles it will produce during cooking so it it better to check the loading quantity.
Regards.
SOURCE: How oftern should a deep fat fryer Oil be change
It depends on how much you use it. If you use every day all day them change oil once a week and cleaned at the same time. If used rarley then change oil when food tasted not as good as it shood.
SOURCE: Hi,i want to know wath is the oil's temperature
I would guess about 120-150F for the oil. There is a screw under a cap on the gas valve that you can use to regulate the pilot, but this is not recommended. The flame must be high enough to heat the thermopile sufficiently so that the pilot will stay on and the main valve actuate. For better or worse, most gas fryers are designed to keep solid shortning in a liquid state when off and to safely melt it overnight. If you need the oiler cooler, say for filtering, I suggest just turning off the pilot.
SOURCE: I need to know the best wayto clean the inside of an IFS40 deep f
Mr. Muscle Commercial oven cleaner, a good brush, a stainless steel scrubbie. Boil out the pot in accordance with Mr. Muscle directions. If all else fails, find "SWELL" oven cleaner in Restaurant supply, use rubber gloves. Spray on, let sit, Use brush and Scrubbie to remove. RINSE WELL!
