My monitor is 21 inch and i am using kworld tv card model kw-SA-A233 out of range
SOURCE: Crack the Driver CD
please try it here let me know if u need further help
http://global.kworld-global.com/main/support_down.aspx?mnuid=1255&modid=14
SOURCE: i need driver for KWorld KW-506RF-PRO
Aqui esta el driver del
KWorld KW-506RF-PRO http://driverscollection.com/?file_cid=390513268530012dba66801272d
SOURCE: when i hook up my kworld pc to tv model kw-pctv
I think th eproblem is from the resolution set in the computer ..depending on the video card you have ...look in the tray system (the right side of the task bar ..where all the working programs are displayed) ..and click (right) on the video driver icon ...and on display modes...and change the resolutions until the image is good..Im not sure which one will work cause there are a few there ...but when the image will clear you will know that that is the one ..Just make some trials..
the issue might be that the resolution set is not fitting with the large screen of the TV ..try a larger resolution for it ..
After that if the Icons seams too small just right click on the desktop ..and go to properties...and settings ..(the last one in the right ) ..and advanced and enlarge the icons and the writing ..
you can also change the resolution from the settings here ..
