This is the third Razor MX 350 I have brought within a year and have had the exact same problem with all three.
I think you can a new dirt bike charger easily on Amazon or on the razor website. Be aware of how you use the battery though, it is the same idea for a lot of mobility equipment (electric scooters, electric wheelchairs, electric bikes, and etc...). You need to use the battery PROPERLY. For example, charge them from time to time, don't leave them there for a long period of time just because you don't need to ride out your electric dirt bike. Your battery's longevity will get hurt. Also, protect it from water and dust. I learn a lot more about outdoor sports equipment on this site: https://mobilityseeker.com/.
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
SOURCE: where do i get a battery for a razor dirt bike?
razor.com they have alot of replacement parts
