Kenmore 46462 Front Load Washer Logo
A
Anonymous Posted on Jun 22, 2014
Kenmore Washing Machine 4027900 leaking - Kenmore 46462 Front Load Washer
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 10, 2008
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Anonymous
  • 5911 Answers
  • Posted on Sep 02, 2008
SOURCE: Leaking Washing machine
I would recommend you inspect the washer with the exterior cover removed, so you can actually see where the leak may be coming from. The following link explains how to replace a drain pump on a Kenmore. I submit this to you, because it not only explains how to remove the exterior case of the washer, but in the event that the pump is leaking, it gives you the necessary steps required to install a new one. The pumps are sealed units and not servicebale. If they leak, they need to be replaced:
http://www.fixya.com/support/r397094-replacing_water_pump
When you remove the exterior case, the washer will not operate without the lid switch by-passed. You will need to do this in order to fill the wash tub to see where the leak may be coming from. To by-pass the switch, you will need to unplug the washer and jumper the two black wires together at the lid switch connector on the timer. Use aligator clips on the connector pins to do this. With the lid switch by-passed, you can plug the washer back in and start a cycle.
Look for signs of leaking around the drain pump (located in the front under the wash tub) and all hoses. Also inspect the entire perimeter of the wash tub for any possible leaks. Generally, if you have a leak in the front of the washer, its a drain pump or drain hose connection. If you have a leak under the tub you may have a worn tub seal or cracked tub.
I hope you find this information helpful. Hopefully, you will not need any repair parts. If you have any questions, please let me know.
PS Use caution when operating the washer with the case removed. There are exposed electrical components and moving parts.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 24, 2009
SOURCE: Tub leak on a Kenmore Washing Machine Model
you could probalby get away with a marine epoxy to repair thecrack (depending on size) , althouth replacing the tub would be the best "feel safe" --- "no longer worry about possible floods". buthte cost and time to switch the puter tub is problably cheaperto buy new machine
Anonymous
  • 331 Answers
  • Posted on Apr 18, 2009
SOURCE: kenmore washing machine series 90 is leaking
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Anonymous
  • 725 Answers
  • Posted on Aug 28, 2009
SOURCE: oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
I have oil leaking on my 110 24622300 Kenmore washing machine
If oil is dripping on your washing machine, you must have something above it that is leaking. Look up to find it.
Your washing machine does not have an engine.
We have a Kenmore 90 Series Washing machine. We
You have a leaking dishcharge pump. Not too hard to replace.
2helpful
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
2helpful
Hi MPT,
SG
1helpful
3helpful
2answers
Alexander
vince
