SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
SOURCE: Sharp lc52d64u power light blinks once, then power
Ur Main Tuner signal board is dead.Replaced that board will fix the problems.Tries Shojimmy.com,Ebay.com to buy a refurbish Tuner board.
SOURCE: I have a Sharp lc-46d62u and it blinking when i
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)...
SOURCE: My Sharp LC-42-D62U won't power up. The power
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
